1999+ DTC Diagnostic Trouble Codes page revised
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1254 times
Post by matthew1 »
1999+ Volvo Diagnostic Codes
Those codes and their meanings are now in the MVS database, which gives much flexibility in how we can use them. It'll be much easier to join them to topics here in the forums, and vice-versa.
Two things that are now immediately better:
  • You can now append the code to the end of that page's URL to make browsers go to that exact code. Try clicking here.
  • I've flattened them to remove duplicates, where two rows were duplicates.
To append a code to the page's URL, take the URL and add a hash mark -- # -- then add the P code. For instance, go to the page and in the URL bar at the top of your browser type #P0727
The other codes pages will likewise be revised shortly.
Voila. You've created a URL that goes to that exact code. What you do with that is up to you, but it's there if you want it. Note this only works with the "P" codes, not the "ECM" codes, and you must type the P code in exactly as it appears in the list.
Also -> Amazon link
