Hello,
I am rebuilding my engine after a bad radiator that caused an overheating problem. I am in the process of putting new rings to my pistons and I am unable to find the needed info about the ring gaps, someone that can Give me a hand.
Thanks a lot and I hope I can give some help as well.
s60 2001 piston ring gap needed
godzilla138
- Year and Model: 2001 s60 2.4t
DGM
- Year and Model: V70 2.4i 2005
- Been thanked: 3 times
This may help.
Piston running clearance (example)
Measured cylinder diameter........ 83.015 mm
Measured piston diameter........ 82.995 mm
The piston running clearance is........ 0.020 mm
The piston running clearance must be 0.010–0.030 mm.
Piston rings
Axial clearance
Upper compression ring........0.030-0.070 mm
Lower compression ring........0.030-0.070 mm
Oil control ring assembly........0.038-0.142 mm
Compression ring dimension
Upper........1,200 -0.010/-0.030 mm
Lower........1,500 -0.010/-0.030 mm
Dimension, three piece oil ring
Spring........1.510 ± 0.020 mm
Rail........0.460 ± 0.011 mm
Piston rings
Axial clearance
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
Are you having the cylinders honed? If you replace the original rings the cylinders need properly honed for the new rings to set. Otherwise you'll have oil consumtion issues. Also, the cylinder bore measurement need to be below repair limit to make this worthwhile.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
- DavidE7
- Year and Model: 01-07 V70, S60, XC70
- Has thanked: 53 times
- Been thanked: 62 times
Resurrecting a very old thread. I can't find a specification for the correct grit to use when honing the piston bores in a Volvo B5254T2 engine in a 2007 S60 2.5T with 265,500 miles. I plan to use a silicone carbide flex hone "dingeberry" tool. The available grits are 180, 240, and 320. The flex hone grits cut less than the comparable stone grits. The new piston rings are from Goetze and are made for the Volvo engine.
Backstory: I am replacing the head gasket because it is leaking coolant in two cylinders #4 and #5. This engine had the head gasket replaced at 226,661 miles in early 2022 because the PCV banjo bolt check valve lost it guts into cylinder 3. The compression wasn't as high as I had hoped at 171, 169, 160, 163, 171 after the rebuilt junkyard head and head gasket were installed. This time I am planning to replace piston #3 because it has marks from impacting the pin and ball from inside the check valve and may have a very slightly bent connecting rod. Also planning to replace the other 4 sets of piston rings, inspect the connecting rod bearings, verify correct tolerance on all the lifters, and see what 40,000 miles of use did to the beautifully cleaned head and valves from the prior rebuild. I am also curious if the valve clearances changed.
There are quite a few sites with recommendations for grits to use when honing cylinders for new rings. I can't find information that is Volvo specific and I hope somebody has this experience that they can share.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 224,000 miles
2004 Nautic Blue XC70 2.5T 251,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 275,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 200,000 miles
P2 Volvos for every person in my family
dikidera
- Year and Model: S60 2005
- Has thanked: 67 times
- Been thanked: 175 times
Because there is none. It is my personal belief volvo never intended for these engines to get rehoned, rebored. No specs no nothing.
The closest you can get to actual specs is from the 850 service manual https://www.volvoclub.org.uk/tech/servi ... vin_55.pdf
This service manual also includes deck warpage, which is a critical component missing from VIDA for the newer engines. Piston ring gaps, almost everything.
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
I used this Flex-Hone 240 grit brush: https://www.amazon.com/dp/B002XUL1F8 + honing oil https://www.amazon.com/dp/B007INQHEU Don't remember where 240 came from, perhaps from Tim Gilles' engine rebuild book. No measurable oil consumption after about 15k miles and 5 years.
- DavidE7
Thank you for the information! I am ordering the 240 grit Flex-Hone and will report back the results. I forgot to write that I searched through VIDA for this info on all the available 5-cylinder Volvos in the 2014 release. I am surprised the engine information for bearing and piston sizes are stamped on the block and crank. I did find inspection data for head flatness in VIDA under, Information: Product Specifications: Specifications Mechanical: 2:Engine with mountings and equipment: 200 general: General, B5254T2: Specifications Mechanical
The piston, bearing, and lots of other engine specifications are in the same location in VIDA.
David E
- Has thanked: 1500 times
- Been thanked: 3812 times
That’s an impressive family of P2s , David
- 339 Views
Last post by BryanInglis
- 2094 Views
Last post by Anarchist
