S90, 1997 brake light (passenger side) not working
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Chwee
Year and Model: S90, 1997
Post by Chwee »
would be grateful for advice - it is not the light bulb, not sure what else to do apart from paying the volvo mechanic to give me his expert opinion (can't afford it). there is no corrosion on the light bulb holder. thanks!
lindy8_man
Year and Model: 1998 S90
Post by lindy8_man »
You can check the switch. I pulled the switch and used a volt meter to verify it was working properly. You will need to follow the wiring diagram carefully.
The other place to check is the two contacts on the back of each of the amber bulbs. the solder gets hot and get's smooshed by the contacts in the plug. They can come together and cause a short.
Once these are ruled out, the rest is not so fun...
Beer and DIY Volvo Repairs are proof that God loves us and wants us to be happy.
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
Check the bulb again. I have found that cheep bulbs made in China don't always make good contact.
1988 Volvo 760 Turbo Wagon
