Hi all,
My car has a rough idle and runs rough when warm (at operating temperature). It is inconsistent, some drives are fine (I have a 70mi drive to work, 90% highway), some exhibit the rough idle issue.
I previously replaced the front O2 sensor (by advice of trouble code). This seemed to resolve the issue for a while, but it came back a few months later (could be a different issue, but same symptoms).
I also confirmed there are no leaks in the vacuum tubes (by smoke machine).
The front O2 trouble code is gone now, but I now have 2 more.
Here are the current CEL codes:
P0300 - General misfire (same before O2 replacement)
P1672 - camshaft reset valve (new)
P0442 - leak diagnostic - minor leak (new - I assume unrelated)
The last two are new since the mechanic did work, and may be the result of a 12 year old car with ~200k miles. I guess I'll start by replacing the reset valve, would this cause a rough idle? If not, any suggestions on what else to check?
2000 S70 - rough idle/misfire
- regent
- Has thanked: 2 times
- Been thanked: 12 times
The misfire may point to ignition components. How old are your plugs and coils?
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- dvlchd3
- Year and Model: 2015 V60 Polestar
That was my first thought as well, however, I would've expected specific cylinders to be misfiring if it were the coils/plugs.
I will check them out when I go to replace the camshaft reset valve (while praying this is the only issue).
- 7965 Views
Last post by barnes89
- 1410 Views
Last post by cuhfs
- 2016 Views
Last post by jtp
- 776 Views
Last post by erikv11
- 1934 Views
Last post by jakeempero
