Tune My Ride! '98 V70 LPT - Fast Friday #13!
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1245 times
Volvo Repair Database Tune My Ride! '98 V70 LPT - Fast Friday #13!
Post by matthew1 »
Welcome to the first edition of Tune My Ride!
MVS Forum member Rich (rmmagow) asks Lucky "What to do for an all-around improvement -- power/handling -- on my 98 V70?"
What do you have?
98 V70 AWD LPT 180,000. Just about stage-0, only minor vacuum related issues to fix.
How much do you have to spend?
$750 to $1000. I'll do my own wrenching.
Where do you want to go with it?
Faster turbo response with more boost available at the upper end, say the 60 to 80 mph range sort of like how the R responds. Better handling, flatter cornering. The car currently does not have the AWD connected, but I'd like to put it back. I also don't want to kill the motor or tranny.
Lucky's Answer
LPT motors are great when it comes to the low end grunt it takes to get AWD cars moving, but the wastegate setting is critical to get that early boost development that makes these cars so nice off the line. If you haven't set your wastegate yet I can't stress how much that will affect driveability. I'd start with a base setting of 3.6psi and see how the boost develops. This will bring the turbo response in a bit quicker. Even with the AWD disconnected this base setting is going to be really important since you have less load against the engine as your drive shaft and rear end/axles are not contributing to engine loading which has a direct impact on boost production.
As for upper end power, that's going to be a bit harder to make any real gains on since the smaller turbo that comes stock on that engine is going to top out flow as early as 4500Rpm. Downpipe and catback exhaust can certainly help to maintain upper RPM power but at the end of the day a larger turbo is going to be a considerable contributor to better upper RPM power and performance. Consider upgrading to a 15G or 16T since they are bolt on turbos and quite cost effective. As you can already guess getting a proper tune will help you get the most out of any upgrade that changes flow in the engine so consider that if it's in the upgrade budget.
Better handling as it relates to flatter cornering is going to be most impacted with a set of sway bars. Springs can help but with AWD, lowering springs can be harder to find and may not be what you want anyway... Sway bars are a hard upgrade to beat as they provide an amazing increase to the nimbleness and handing of the car with nearly zero side effects or negative trade offs.
Hope this is helpful in getting you to your power and performance goals, if I've missed anything post up below and I'll be sure to reply shortly!
Robert Lucky Arnold
[list][*]Questions, comments, arguments and freakouts accepted and encouraged. Really. Lucky WANTS to answer your questions.
[*]If you want to remain anonymous, email me your question or comment and I will post it as "Anonymous User".
[*]It takes Lucky and me several hours combined to bring you Fast Fridays. Your questions and comments validate FF's value.
[*]I write paragraph headlines, and sometimes article headlines. Yell at me if you find these not to your taste.
[*]Same thing with italics and bolds , they're all mine.[/list]
Matt
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
Lucky, do you recommend any of them for rmmagow's '98 V70 LPT?
Also -> Amazon link
awdsubaru
Year and Model: V70 2.4t, 2001
Post by awdsubaru »
I know it gets said over and over on this site, but its my turn now! I truly love this site. It has helped me out so much over the years. I especially love the " Ask Lucky"! Way to go guys, keep up the good work! Thanks for all your efforts.
Current: 2001 v70 2.4T 185,000km
Past: 2002 V70 Base 265,000km
1996 850 glt 290,000km
1996 960 425,000km
arnabio
Year and Model: 1999 V70XC
Post by arnabio »
These are great. Thanks a ton!
My questions are specific to my car (99 v70xc):
I am considering upgrading to a 16T:
A. Where would I find one?
B. I've read in various places that some people just bolt on a new compressor side and leave the hot side. Is it better to upgrade the whole unit or to do this? My car has about 109k on it and I believe the turbo is in good shape
C. If I were to do this, I would like a new exhaust, but it seems impossible to find a full, turbo-back solution for the awd v70s. Would I need to have a custom one made?
D. Would the stock injectors be adequate for this type of setup?
E. Would I benefit significantly from an FMIC?
Thanks in advance for answers to this smorgasbörd (yay scandinavia!) of questions
Aaron
ARD-Lucky
Year and Model: 1994
Post by ARD-Lucky »
matthew1 wrote:Lucky, your company ARD sells tunes and other performance goodies. Do you recommend any of them for rmmagow's '98 V70 LPT?
(Lucky is too modest to push ARD products, but I'm not!)
Thanks for the kind word Matt, truly appreciated!
As for tuning we're always happy to talk with each person and determine their goals before we suggest an upgrade, it's not always the right choice for everryone. However in this case an ARD tune might very well help to reach the power and performance goals that we're talking about and it would be a good place to start when you consider hp per dollar.
ARD-Lucky
Post by ARD-Lucky »
arnabio wrote: My questions are specific to my car (99 v70xc):
Aaron
A. Ebay, Craigslist, Salvage yard, or we can order rebuilt units for you. Pm for more details!
B. The problem with that is that the compressor should be balanced to the turbine as well to ensure good turbo longevity, so that's not advised. If however you mean simply keeping the turbine side exhaust housing but swapping in the Center Housing Rotating Assembly (CHRA) then that is fine so long as you are careful during install.
C. Exhaust wouldn't be necessarily required but a downpipe upgrade might be well worth it depending on power goals.
D. typically yes, if you keep it at or under 14psi
E. Somewhat dependent on your area, up here in the PNW I'd say probably no.. in the southwest then perhaps yes!
Thanks
