N/a 240: Walbro 255 fuel pump questions
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Yarbles
Year and Model: 240 1991
Post by Yarbles »
I need to replace at least one fuel pump; buzzing main pump and occasional stalls; so I'm considering the Walbro 255 in-tank pump to do the job of both.
Will I need to replace any other parts? Will the pressure regulator be ok with a higher pressure supply? There's an HP version for $10 more which I'm considering in case of future turbo upgrade, would there be any issues using that?
Oh and finally, what's the thing next to the main fuel pump slung under the car? Looks like a fuel filter but I seem to remember it being downstream of the pump..
Lots of questions I know but I'm trying to get my head round how the whole system works so any info appreciated.
Thanks,
Yarbles.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
I'll answer the easy one first: the thing next to the fuel pump is the filter.
Volvo 740s with the Regina fuel system do use only an in-tank pump and the series 1 Volvos used them. Without knowing pressure specs I wouldn't be prepared to commit myself.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Yarbles
Post by Yarbles »
Well I saw a graph showing the Walbro sustaining 80-100 psi at the flow rate I'm expecting but I don't know about the stock pump. I'm wondering if the Walbro could give more pressure than the regulator can handle and cause it to fail.
billofdurham
My information shows the stock pump to be rated at 4.5 - 5.3 bar or 65 -76 psi.
The book also shows that the fuel pressure must not exceed 84 psi.
Bill.
Previously:
jimmy57
Been thanked: 320 times
Post by jimmy57 »
The under car pump is a long-lifer but the in-tank low pressure stage pumps are crap. The undercar main gets loud when the in coming fuel is foamy from failed in-tank pump. IF you do the two stage in-tank with a walbro it will be loud and you will have issues on how to get the plumbing done to attach the now high pressure hose to the fuel filter. You will need to replace the hose from tank all the way to fuel filter as that is not a high pressure hose from factory.
Yarbles
Post by Yarbles »
Do you know if the noisy Walbros were rubber mounted at all? I read that they're a smaller diameter so need some kind of sleeving to mount them..
For the pressure issue I've seen adjustable universal regulators for not too much money. Should that take care of everything?
