V70 VERSUS THE S70 Topic is solved
JC
V70 VERSUS THE S70
Post by JC »
What is the difference, I thought I had a v70 t5, I have a s70 t5, are the brakes the same on both, I just had them replaced rotors and pads. My parking brake does not work as well since the brake job, do I need to adjust this is also.
Thanks
jc
Guest
Post by Guest »
The V70 is a station wagon, the S70 a sedan. The brakes are likely the same. The people that replaced the brakes should have adjusted your ebrake.
Jot
Year and Model: C30 2010
Post by Jot »
The E-brake adjustment is located in the center consol under the cup holder. It's an easy DIY
