Hi, first time poster.
have found some posts regarding this problem but none which contain a solution.
Our cd stacker had never worked. Today I pulled the stereo out and found that the cd stacker was not even plugged in. Plugged it in, put everything back in place and now I get nothing.
The screen doesn't light up and I'm not prompted for a code at all. The only sign of life is the security light flashing. The fuses are fine. Have tried holding down the #6 button.
Anybody got a solution for this?
stereo sc811 wont power up. security light flashing.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Maybe you can unplug the CD changer and it will work again.
- rspi
Contact rspi..
Something must have shorted it out. Maybe you can find a cheap replacement. Did it have a CD player built in?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Unplug it, set it aside for a day, and let the capacitors all drain. Then try again, holding down the power button as you plug in the connectors to the back of the radio and turn the ignition key. I've heard of these things being super finicky.
'98 S70 T5
2016 Chevy Cruze Premier
- Has thanked: 2658 times
- Been thanked: 1248 times
> apologies to administrators for duplicate thread
No problem. Welcome to MVS. Down Under is well represented here.
- pkc303
- Year and Model: 1995 T-5R Yellow
- Has thanked: 1 time
- Been thanked: 3 times
I think you have to leave it powered for a couple of hours, and then the code requirement will appear. It sounds exactly like you entered the code more than three times, and it locked you out. I've done it a few times. This is what it looks like when you do such a thing. Good luck.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
- rspi
Contact rspi..
You only have to do that if the display says OFF.
