so what else can i do ???? 850 t5 auto
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
adey
Post by adey »
ok ...i changed the rotor arm,dizzy cap,plugs,checked all my pipes ..but when i slam the pedal down it doesnt seem as quick as my v6 vectra...
any ideas ...please as this t5 is said to be 222bhp it really doesnt seem as quick as everyone says these things should be
help 8)
Guest
Post by Guest »
adey wrote:ok ...i changed the rotor arm,dizzy cap,plugs,checked all my pipes ..but when i slam the pedal down it doesnt seem as quick as my v6 vectra...
help 8)
My 95 acted similar until I changed a few parts. First thing I would do is read the codes at the front of the car. You can extract them by following the guidelines on this site. Write down the codes and clear them. You might need a Oxygen sensor, or maybe a MAF sensor. When I changed mine that's when it came to life. Depending on the weather (colder being better) your car should easliy spin the tires from a stand still. Check those codes.
Brian
Guest
Post by Guest »
help 8)
Brian
thankyou my friend
