2003 V40, T4, Auto, 126,000 - $5,500 OBO
zulu-v40
Year and Model: 2003 V40
Post by zulu-v40 »
FOR SALE
2003, Volvo V40, 1.9 T4
126,000 miles
$5,500 or best (reasonable) offer [I've put thousands into getting this car back to Stage 0, so I will not accept lowball offers. Plus, I'm including lots of odds and ends specific to the car.]
Pictures to follow. If interested, please send me a personal message.
08/01/11 - Spark plugs and wire set, boost pressure sensor
08/01/11 - Full alignment, new rear tires
08/08/11 - EVAP Purge Valve (OEM)
08/13/11 - Fuel Filter (Bosch)
08/19/11 - Idle Air Control Valve (OEM)
08/26/11 - Front and rear brake pads, bled brakes (Centric, DOT4)
09/23/11 - Front and rear oxygen sensors (Bosch)
10/06/11 - Thermostat, Enginge Coolant Temp Sensor, Ignition Coil Pack (OEM)
12/03/11 - Battery, Fuel Pressure Regulator and o-ring, Silicone Vacuum Hoses (Duralast, OEM, aftermarket)
02/04/12 - Catalytic Converter, Air Filter (Bosal, K&N)
02/05/12 - HD Turbo Control Valve, Boost Gauge (iPd)
02/16/12 - Timing Belt, Idler Pulley, Tensioner, Water Pump, Serpentine Belt
03/04/12 - Positive Crankcase Ventilation system overhaul, Intake Manifold Gasket (OEM)
03/06/12 - Front brake rotors, Transmission drain and fill (x3, 10 quarts) (Centric, Mobil 3309)
03/10/12 - Rear brake rotors, Installed floor mats (Centric, OEM)
03/17/12 - Transmission drain and fill (x1, 3.5 qts), Replaced Transmission Drain Plug and washer (OEM)
04/20/12 - Front left and right sway bar bushings replaced
06/01/12 - Replaced Throttle Position Sensor, Cleaned throttle body, replaced Throttle Body and Idle Air Control Valve gaskets, replaced Intercooler Hose to turbo along with clamps, replaced Fuse Box (cabin) (OEM)
06/18/12 - Replaced Cruise Control and Brake Switches (OEM)
08/01/12 - Replaced all lightbulbs in tailgate, Rewired electrical harness in tailgate
11/xx/12 - Exhaust Manifold and gasket (getting done this month)
11/xx/12 - Aluminum wheel rim (getting done this month)
Car includes the following DIY goodies:
*Box of Mehle oil filters x9 (each box has an oil filter, oil filter housing ring, and washer)
*Oil filter cap wrench (specific to car)
*Box of Mobil ATF 3309 transmission fluid (7 bottles)
*Spare transmission drain plug w/ 4 washers
*24mm box end wrench for transmission drain plug
*Spare thermostat housing gasket
*Spare throttle body gaskets x2
*Spare idle air control valve gaskets x2
*Left over silicone vacuum hose
*Custom fit pod gauge, has been sanded down, needs matching paint
*Receipts for almost all replacement parts
*For those interested in installing an aftermarket head unit, I'll include the following:
-Autoleads PC9-414 Wiring Harness Adapter
-Metra 70-9221 Radio Wiring Harness for Volvo 99-06
-Metra 40-VL10 Volvo Antenna Adapter
-Volvo Genuine Part - Box, 30613741 and extra mat for box
*Old pc tower loaded w/ VADIS
*S/V40 Hayne's Manual (hard cover)
The Good:
*Yakima Car Top Carrier (w/ keys)
*Pet Divider for tailgate (great for big dogs)
*Pet sunscreen for rear windshield
*Premium Sound System w/ Subwoofer
*Keyfob w/ remoteless entry and Security System
*Power locks and windows
*Leather (some wear and slight cracking, but no tears)
*Rubber floor mats (easily washable, great for winter)
*Centric Power Slot rotors, Centric brake pads
*iPd Turbo Control Valve
*iPd Boost Gauge (Mechanical)
The Bad:
*Left passenger side door opens from inside, but not from outside (mechanism inside door needs to be replaced)
*2 small dings on windshield
*Paint on body shows signs of wear/discoloration some scratches and dings
also listed on craigslist and autotrader.com
2003 V40 T4, silicone vacuum hoses, K&N air filter, iPd Boost Gauge, iPd HD TCV, PowerSlot Rotors
zulu-v40
Post by zulu-v40 »
$4,000
zulu-v40
Post by zulu-v40 »
12/10/12 - Exhaust Manifold replaced along with all associated gaskets and washers (OEM), driver's side passenger door lock actuator replaced (OEM)
12/11/12 - New all season front tires
Asking $5,500 OBO (given repairs)
zulu-v40
Post by zulu-v40 »
03/03/13 - $4,000 OBO - 131,600 miles
zulu-v40
Post by zulu-v40 »
SOLD
