Volvo 740 GL engine is tapping Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Ami27
Post by Ami27 »
I am hearing a distinct tapping noise in the engine of my 740. The car now has approx. 176 k miles on it. I am told this is a lifter. Is it something that NEEDS to be repaired or can the Volvo engine survive well with a worn lifter?
(My dad says it's really nothing to worry about....)
I do love that car, and want it to last a long time to come.
Probably one of the best cars I've ever owned, 15 years old and runs like a charm.
~Ami~ :D
Kmaniac in California USA
Post by Kmaniac in California USA »
According to my service manual, the valves in the Volvo are adjustable. However, instead of screw and nut adjustment, these things use removable shims. I suggest you pull the valve cover and check the valve lash. Most of these cars should have the valves lash checked and adjusted as needed every 30,000 to 60,000 miles. A little maintenance will help your car go much farther.
Chris the "K MANIAC"
1986 740 GLE
(5) 1964 Chrysler 300-K's
