Fifth cylinder won't fire
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
diveshack
Year and Model: 850 and 1995
Post by diveshack »
The fifth cylindar of 1994 volvo 960 will not fire. Checked spark plug and ignition coil. No spark whatsoever is reaching plug. Comments???
cmblackburn
Year and Model: 1998 S70 T5M
Has thanked: 1 time
Been thanked: 7 times
Post by cmblackburn »
They have a coil on plug ignition system. if they're original to the car then voltage could be leaking out through small cracks in the plastic part going down into the cylinder-you may try wrapping it in electrical tape for a temporary fix/confirmation. You can replace that one or all of them.
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Also, swap the coil to another cylinder and see if the problem follows.
