98 S70 lost all power like a lightswitch
98 s70 lost all power it was like the neg. cable was taken off the battery its happen twice in the last month starts back up the next day anyone have this happen towing is costing me and arm and a leg
Reason: Edited title for clarity.
volvobaggen
- Year and Model: 850 -1997 B5252s LPG
Sounds like a bad fuel pump relay. If I were you, I would try replacing it. It doesn´t cost much.
- Year and Model: Many Volvos
- Been thanked: 75 times
Does everything shut off, stuff like the radio - etc. If so check, double check, and then check again all of the battery cables including the B+ cable that branches off of the + battery cable. Also check where the B+ cable bolts onto the post in the fuse box.
From there I would suspect the electrical portion of the ignition switch.
search Voltage Drop and read how to check the B+ cable
https://www.matthewsvolvosite.com/forums ... =1&t=35208
99 V70XC 158K
95 850glt 188K
95 850glt 188K
