Lately I've noticed a number of XC-70's that need a transmission. Has anyone successfully put a M56 into a 2001+ XC-70?
I've got a '94 850 with the M56 and found a 2002 XC-70 for sale in my area with only 124,000 miles.
I think that it will physically bolt in (might have issues with the slave cylinder) but has anyone found an answer for the ECU modifications and any other nuances?
I've seen these posts but haven't seen anything where someone has done a swap for these years (94-2002) and resolved the ECU mod or other issues.
https://www.matthewsvolvosite.com/forums ... =1&t=28887
http://forums.swedespeed.com/showthread ... -turbo-v70
http://volvospeed.com/vs_forum/topic/15 ... -2000-s80/
xc-70 m56 swap
absolutezero273c
- Year and Model: '94 855 N/A 5 spd
xc-70 m56 swap
1994 BMW 540iA, 180,000 (DD)
2001 Ford Excursion 7.3 L, 213,000 miles
Others in my fleet requiring regular maintenance:
2002 Ford Windstar SE
1995 BMW M3
1995 BMW 740i
2002 BMW 325xi
2003 BMW 325xi
1995 BMW M3
1995 BMW 740i
2002 BMW 325xi
2003 BMW 325xi
The transmission will bolt up, but im
Not sure what the ecu requires to run properly on the p2 platform with a manual swap.
I converted my 850 turbo to a manual once, no experience with the newer v70's tho
2003 v70 2.5tawd black/black 120miles
2007 nissan altima 2.5 cvt 107miles
2001 xc70 211 miles " collision"/ parts car
1994 850 turbo 315miles 5 speed "stoped fixing it"
absolutezero273c
Thanks for responding Japedo. I was doing some reading on that year and it looks like that year the S80 P2 made use of canbus for communications/controls. Not sure if the 2002 XC70 P2 does as well. I can't seem to find any info with a quick look but if it is anything similar then I would have to say all bets are off with using the M56. ...And I don't have the time to try to make it work.
1995 BMW M3
1995 BMW 740i
2002 BMW 325xi
2003 BMW 325xi
1995 BMW M3
1995 BMW 740i
2002 BMW 325xi
2003 BMW 325xi
Here's a quick write up on manual trans swap for P2 cars.... we've done a number of them lately so it's a pretty straight forward process. https://www.matthewsvolvosite.com/forums ... =5&t=53702
If you keep your AWD however you'll need to source an M58 or M66, if you ditch the AWD then you can use the M56.
Let me know if you have any other questions!
absolutezero273c
Thanks Lucky. Would there be any advantage to going with the M58 over the M66 or vice versa for strength or longevity reasons? Reason I ask is I own a Ford Excursion and had to rebuild the trans. While looking into my options I found that with each subsequent transmission model they have made for the SuperDuty chassis they have improved it. Just wonder if the same exists here. If not I figure it just comes down to availability.
1995 BMW M3
1995 BMW 740i
2002 BMW 325xi
2003 BMW 325xi
1995 BMW M3
1995 BMW 740i
2002 BMW 325xi
2003 BMW 325xi
Gatewood
- Year and Model: 1996 960, 2002 V70XC
It looks like someone gave up partially through their attempt at this and is selling their project on ebay:
2001 V70 w/ M56 manual tran
