freak'n heater core job...how do i?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
carboncow
Year and Model: 2003 XC70 2018 S60
Post by carboncow »
1. How the hell do you get these bizarre proprietary clips off the heater hose at the firewall junction? I appears from several write-ups they have to come off so the interior pipes can move around...is this correct? and if so how the f%^$%$ do you get them off?
2. How the hell do you get the clips that attach the pipes to the old heater matrix off? they push toward the rear of the car but the lower one starts hitting plastic "stuff". Do you have to half pull the core out before you can pull the clips out?
I'm completely stuck as these clips have beaten me this evening.
Looked like a straight forward job until you realize you needed to go to some swedish ninja coupler boot camp to know how these evil devices work.
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
1999 Porsche Boxster
2004 Chevy Suburban LT 5.3L
2013 & 2015 S60 T5
2008 Vw Touareg T2 V6
1989 Sea Ray 340 Sundander
2007 Sea Doo Challenger 180 SE
carboncow
Post by carboncow »
I"m going to add to my own post...I got some really bad advice with write up on this project. The old core had to be destroyed to get out. Don't let anyone tell you it will clear the steering column because the new one will clearly NOT go back in with the steering column in place. The angle required for the heater matrix to be pushed back in and not hit the column will not permit the top of the matrix to enter into the hole...
I am currently stumped with no knowing how involved removing the steering column is or having to dremel out the entire bottom of the box to allow for the proper entry of the matrix...this is hands down the worst core job I've ever done and this inclues a Vw that the entire dashboard should have come out...bad advice given and taken!
Which route have you guys have to take to get the core back in?
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
You may have got more help by posting which model of car you'te working on. Many of us log in with Tapatalk which doesn't show signature or car model.
If this is an 850 or P80 series V70 or S70 you can first undo the pipes at the heater core by means of a centrally located torx screw. After doing this release the heater hoses then release the coupler from the firewall via the 2 small torx screws at the firewall side. This method will give you far more flex in the metal pipes so you can pull them out. It goes without saying that a new coupler should also be fitted to avoid leaks in both the cabin and engine side
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Never had one go bad on a P2 but I don't think the column has to be removed
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
...unless the swedes built the car around the core...:
:lol:
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
slione
Year and Model: XC70 2002
Post by slione »
regent wrote:...unless the swedes built the car around the core...:
:lol:
I did a heater core in a Nissan once. Worst project I ever did. I swore the core was the first part bolted to the pan on the assembly line. Whole dash had to come out to get to the damn thing. After I got it all back together, I only had about a dozen miscellaneous parts without a home. :oops:
____________________________
02 Volvo XC70, 174,000+ mi
09 Honda Pilot
74 VW Super Beetle Convertible
DGM
Year and Model: V70 2.4i 2005
Been thanked: 3 times
Post by DGM »
carboncow wrote:1. How the hell do you get these bizarre proprietary clips off the heater hose at the firewall junction? I appears from several write-ups they have to come off so the interior pipes can move around...is this correct? and if so how the f%^$%$ do you get them off?
The attachment IMG_2604.jpg is no longer available
They are twist lock type.
Heater core coupling .JPG (52.02 KiB) Viewed 1027 times
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
carboncow
Post by carboncow »
Does anyone know from experience how to get the pipes with new gaskets back into the core. We are are on our 3rd night of trying to figure this out.
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
