I was driving to work, exited off highway and stopped at light. S90 began to idle/diesel/ no power. I was able to coast to work.
I have checked compression avg. 132psi, have spark, have fuel at injectors, replaced crank sensor, replaced ECU, cleaned cam sensor, new plugs and removed cat/exhaust no start. Timing marks are dead on! Assistance is much appreciated. 2.9l w/165k miles. Ignition Control Module? IAC?, MAF?,
Cheers
98 S90, Cranks won't start!
- regent
- Has thanked: 2 times
- Been thanked: 12 times
Are injectors 'pulsing'?
If no, then check for the common (+) power supply to injectors (I am assuming you have the Denso or Motronic arrangement with switched (-) ground from ECU). If OK, then: Is your Fuel Pressure OK?
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- Year and Model: Many Volvos
- Been thanked: 76 times
Moved to the correct forum.
lindy8_man
- Year and Model: 1998 S90
How is your spark? I had a coil pack quit on me once and it idled pretty crappy, and I limped it home. Check for spark on all your plugs. With new plugs do you see any wet ones? Any codes?
Beer and DIY Volvo Repairs are proof that God loves us and wants us to be happy.
- 573 Views
Last post by Volvopetrol
- 3782 Views
