Hi guys, I know this is a minor issue, but not sure if I need to replace a valve or just clean it out.
I noticed my passenger side sprayer on the hood was a little weak, as well, I don't get anything spraying on the headlights.
I popped the hood up and gave the sprayer a blast, turns out fluid is shooting out the bottom of the hood onto the engine.
There a little L valve from the hose to the actual nozzle on the hood, and the washer fluid is just shooting out the bottom. Looks pretty funny.
Here's a picture - so can I clean this valve out or do I need to replace it with a generic L valve from a auto parts store?
It also appears the same thing is happening with a similar valve at one of the headlights
Thanks so much
Steve
Sprayer valve under hood
Windshield fluid spraying onto engine!?
bskeels
- Year and Model: 1997 Volvo 960
- Been thanked: 3 times
That is a check valve that has gone bad. You can find them at IPD, or FCP, or Volvo. You could replace with a "L" from the local store, but these hold the pressure so fluid is there and ready.
The Fleet
2012 Ram 2500
97 Volvo 960
98 V70 AWD (208000+)
66 Volvo 122s sedan project
98 Volvo V70 XC (151,000+) parts car
08 Volvo V50 T5
"Human history becomes more and more a race between education and catastrophe" - H. G. Wells
2012 Ram 2500
97 Volvo 960
08 Volvo V50 T5
Ahhh right, that makes sense, wasn't sure the purpose of the valve inside....thanks for the reply, looks like both failed, the one on the hood and the one for the headlights, thanks for the details. Will see what I can find tomorrow.
Steve
Steve
difflock54
- Year and Model: V40 Nordic 2002
- Has thanked: 7 times
- Been thanked: 2 times
Looked on my V40 which is set up a bit differently. (my hood liner is missing so all easily seen)
Sh has a single 'T' non return valve mounted centrally with a short hose each side to the hood sprayers.
The single hose to bottom is supplying water from the washer reservoir / pump unit.
Aging and / or heat from engine has probably caused a hairline split in the plastic valve itself or the slip on hosing is splitting slightly allowing a leak under pressure.
The valve is to avoid air locks in the system and to ensure instant water supply to each sprayer.
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
Huh?Rocky wrote:Btw you don't want anti freeze type washer fluid spraying inside the engine bay.
It's flammable.
Never heard that before. What gives?
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
There's methanol in it!
What do you think prevents it from freezing? Yep, alcohol will do the trick!
'98 S70 T5
2016 Chevy Cruze Premier
- alschnertz
Hmmm. Sounds like it's time for an experiment.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- Has thanked: 1505 times
- Been thanked: 3818 times
It's about 30 percent methanol in water. I think it will be tough to ignite that mix under hood, even on a hot exhaust manifold. Still, I wouldn't want it spraying all underneath, either.
- 591 Views
Last post by hankeester
- 1075 Views
Last post by jesselks
