1998 V70 T5-M - $6900
TyConn
Year and Model: 1994 854 5 speed
Post by TyConn »
This is hard to do, but the time has come to sell my 1998 V70 T5M. The car has 173K miles on it, and about 17K since the engine was re-done.
I bought it a little over a year ago from Steve (Ghost Shadow) after he rebuilt the engine due to a bad head gasket. You can see what he did with the car here:
http://volvospeed.com/vs_forum/topic/14 ... anual-v70/
I bought it from him and have been driving it and adding on little things here and there ever since, but my father passed away recently, and now that I have his car, I have to let mine go. We just don’t have the space or finances for 3 cars in a two-person family, and I need the money to pay for college, etc.
Without further adieu, here’s what’s been done to the car within the past 20K miles between Steve and myself:
COMPLETELY rebuilt head and cleaned pistons. It’s better to read about it in the thread I posted above, but here are some of the cliff notes:
• Complete head gasket Kit
▪ New In Heater hose
▪ New Out Heater hose
▪ New Heater core coupler clips
▪ New Lower Radiator Hose
▪ New PCV kit
• New Vacuum Hoses
• New Alternator (180amp, 220amp peak)
• New Cap, rotor, wires, volvo spark plugs
• New Starter
▪ New turbo return line gasket
▪ New turbo return line o ring
▪ New copper rings for fresh oil feed
▪ New cooper rings for coolant line feed
▪ New timing belt
▪ New idler pulley
▪ New tensioner
• New water pump
Things I did maintenance wise:
• Synthetic Blend 5w-30 Oil change every 3K on the nose
• New Cam Position Sensor
• New MAF sensor
• New Meyle HD Control Arms, Sway Bar end links
• Passenger side wheel hub (FAG) with new bolts
• Brand new rear brake pads, rotors, and hardware
MODS ON THE CAR:
Engine:
•Front Mount Intercooler with BOV (LOUD)
•3 inch Turbo-back exhaust (OBX downpipe, magnaflow cat and muffler)
•ARD Green Tune with SAS delete
Cosmetic/Electronic:
•Compustar Pro RF-P2w901-SS Car Alarm and REMOTE START
•Motorola IHF1000 with a mss switcher (Bluetooth hooked into stock stereo)
•ABM Projectors with LED strips
•Rear wing (Black)
•Window Tints all around (5% in back 20% in front)
•XC Grille with R badge (lol)
*Interior LED lights and license plate lights
•2 gauge pod with Boost gauge
•R-style fog light grills
Suspension/Brakes:
•New Rear Pads and rotors
•Koni STR-T (Reds) All around, brand new suspension hardware (IPD HD Spring seats, bump stops, washers, boots, bolts, etc) on IPD Blue springs
•16 inch Meteor wheels, ok tires on there now, will come with 4 BRAND NEW, NOT EVEN MOUNTED 16 INCH TIRES. Literally haven’t even picked them up from Tire-Rack yet.
Things that will be included with, but not on
the car (Asking price adjustable based on what you do/don’t want)
• Complete 302mm Brake Kit (ATE slotted rotors, Brembo Brake Pads, 302 Brackets, Stainless steel lines for front and back)
• New, in the box, R Clutch and Pressure Plate
• Another wheel bearing (got two, only needed one side)
• Inner and Outer tie rod ends (OEM and Meyle HD)
• OBX Angled Downpipe with extra bung for Wideband
• Part of a Scone-man intake pipe
• 960 Throttle Body and Plate
• Short shift kit
• MSD Coil
• 4 Original Perfo Rims
• Rear Cargo Mat
• Roof cross bars
• Rear arm-rest with cup holders
• Spare Intercooler and Radiator
• Original Grill
• Extra Sunroof assembly
• Extra set of floor mats
• Extra Passenger Axle
• Extra Alternator and Compressor
• Silver R Bumper
• Extra Fog light, OEM Blinkers, and Headlights.
• Brand New Air Filter and Cabin Air Filter both in the box.
• Original suspension struts from the front (still fairly good)
PROBLEMS:
The following will be fixed BEFORE the buyer picks up the car:
• Slight oil drip from the drain plug, just need to put a new crush washer on.
• Drivers door check makes that damn popping sound (needs to be welded)
• Slight dent on rear quarter panel from my friend’s mother trying to back out of her driveway, and slight paint transfer on front bumper from some asshole in a parking lot. Both of these will be fixed at a body shop before the buyer picks up the car and the car will be detailed.
• Tailgate rattles, I have the rear panel off to try to fix it, but the tailgate open light is on on the dashboard now so I probably need a new latch.
• I will have an alignment AND oil change done before it’s picked up
• CEL on for EVAP code, gotta track it down, or if you want, you can delete the EVAP system with a re-tune.
PRICE:
All things considered, my asking price is $6900 for the car, and I will deliver it within 200 miles of 06248.
As I said, price can be adjusted depending on what you want with/on the car. Please don’t be shy about PMing me with offers or questions, the worst I could say is no!
PHOTOS: INTERIOR AND ENGINE COMING SOON!
http://s419.photobucket.com/user/tiberi ... 0%20T5%20M
Xpletive
Year and Model: V70 1999, 850 1997
Post by Xpletive »
PM'd :D
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
It sold a few weeks ago :(
