Arrow is flashing in the dash and in center console for econo/sport. causin the car only start moving at like 2500 rmp. In the morning when car is cold it does not want to shift into 2 gear just revs up and nothing. once you stop and let it heat up it shifts fine. I read that flashing arrow is caused by bad PNP switch... but what about my shifting problem?
Thanks!!!
arrow flasshing and shifting problem Topic is solved
ABS Pump Replacement DIY for 2001-2009 S60
- Has thanked: 17 times
- Been thanked: 35 times
Similar problem with my car a few years ago. Battery terminals were dirty and battery was low on charge. Check there to see if there's a problem.
- 2826 Views
Last post by jimmy57
- 742 Views
Last post by Clemens
- 1684 Views
Last post by SuperHerman
- 2241 Views
Last post by BMWFan
- 1241 Views
Last post by 95850turbowagon
