My s40 has had the check engine ligth on for the longest time, first the code came up as a mis reading in the coolant temp.
I changed the Coolant temp. sensor (an OEM) and ligth went of now it gos on and of every 2-3 days and I checked it out and its the harness that's touching the headers and since some of the wires are kinda showing the heat reading is off again, anything I can cover the whole wire with without buying a new sensor ( sensor has about 150 mi used since replaced)
2000 s40 1.9T Temp. Harness
Villegas_TP
- Year and Model: 2000 s40
