can someone tell me how to replace a cam sensor, and where it is?
thanks
CAM SENSOR
Amsoil Power Foam
White850Turbo
- Year and Model:
Cam sensor is on the driver's side of the exhaust cam. I don't remember what's holding it in, but it's a Volvo, so I'd imagine that it's a torx screw.
-Sean
1998 S70 T5 (Almost Stock)
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 4 times
The camshafts are atop the engine under cast aluminum covers. The exhaust cam is under the rear cover (the side the exhaust manifold is on).
Changing the sensor is very simple, but a Chilton's or Haynes manual would be a great aide to familiarize yourself with your engine before undertaking this repair.
Thanks,
I just replaced plugs, wires, cap and rotor. I'll try to locate a cam sensor online, that will be next weekends project. Had a hard time working around the turbo piping but i got it done. Runs great once its started. Trouble is have to push on gas pedal when starting. Read a post where somone said it was a cam sensor, might as well try that. Guessing still cheaper than going to dealer.
1998 S70 GLT 145K
1993 850 GLT 172K
1993 850 GLT 172K
- 23 Replies
- 2539 Views
- 730 Views
Last post by Mikestaz5
- 883 Views
Last post by carboncow
- 319 Views
Last post by Ronnie1
- 1489 Views
Last post by iRenaissanceMan
