Hello all who have helped me in the past!
I have a 1998 V70-xc with 203000+ miles, the car has been maintained fairly well, not perfect, but it is still in pretty good condition overall. My problem is that I've been getting a noise in the back when I make a right turn and accelerate. It sounds and feels like running over a loose gas or drainage grate on the road and when it started I didn't think about but it became obvious it is the car, it happens whenever I turn to the right and accelerate, like turning and going up a hill. I don't know if it is related but the track light also came on twice while driving straight, I switched it off and that was it. I should mention that I replaced the Track/ABS module about 6500-7000miles ago (with great directions from this site).
Any thoughts of what might be causing this?
Thanks,
Noise in back when turning
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Is your propshaft still installed? These are the early signs of the CV joint in the shaft going bad (more of a banging noise like what I believe you're describing) or the VC dying (more of a grinding noise when turning).
'98 S70 T5
2016 Chevy Cruze Premier
Thanks for the answer.
As far as I know my propshaft is still installed. I bought the car used a few years ago and I never removed it.
Is there any test I can preform to have a better idea if it is the CV joint?
Thanks,
Thanks,
jblackburn
https://www.matthewsvolvosite.com/forums ... =1&t=23969
https://www.matthewsvolvosite.com/forums ... =1&t=46776
Some people that have had theirs fail. You can try a search on 'AWD propshaft or driveshaft' for more accounts. A pretty common problem with the AWD models as they get older.
'98 S70 T5
