Abs light on ?(any suggestions)
Volvo S80
- Year and Model: 1999
- Has thanked: 7 times
- Been thanked: 2 times
Volvo S80 abs light on i had replaced front and rear brake disc`s also brake pads and handbrake pads I was thinking that the brake disc`s and pads were the main cause of the abs light because they were gone for quiet a while also while i was changing the brakes i cleaned the abs sensors which were not to clean there i found some rust some mud etc, I cleaned them repainted the brake calipers and the abs sensor houses used some brake lube (Ate plastilube) but i`m still seeing that Abs light and when i push the button in the speedometer it show`s a number (22) it could be the abs module
but is there any way i can reset it by myself or the only way is at dealer ? Also i have a problem that i can`t understand what the car is saying because it is in german language (Abs wart erforderl)??????
