Ok -- So who does real time engine performance monitoring with a Smartphone?
What app are you using to do so?
Where did you get the app and what did it cost?
What hardware is associated/required?
What type of phone are you using?
What data does it capture/display?
How useful has the ability to conduct this monitoring actually proven?
Any other thoughts/comments/words of wisdom on the subject?
Real Time Engine Monitoring with Smartphone - Questions
Smartphone Apps & Volvos
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
xtrattitude4u
- Year and Model: 1998 S70 2.4l N/A
I am using the ELM327 bluetooth adapter with my 1998 S70. Got it off amazon.
The "newest mini elm327" fit under the armrest quite well.
I got it for less than $20.I believe it will work for any blue-tooth capable phone.
I am using the Torque app on my android-based samsung galaxy s2. Downloaded on my phone from google play.
Torque is fantastic. You can try the free version first,
but the pro version is only $5 and is worth much more than that.
All these features work on the s70: (except for boost haha)
short/Long term fuel trim
O2 sensor voltage
emissions status indicators
vacuum
coolant temp
throttle position
manifold pressure
Turbo Boost
RPMs
Does 1/4 mile and 0-60 times.
Reads fault codes also, but I dont have any to test that out.
Was probably the best $25 I ever spent . . .
O2 sensor voltage
vacuum
coolant temp
throttle position
manifold pressure
Turbo Boost
RPMs
- E Showell
Ok -- I'll bite -- and further display my ignorance . . .
So what is fuel trim anyway and why do I care if I can read it? What does it matter short term/long term?
Has the ability to read any of this information actually made a difference in how you drive/maintain your car?
And notwithstanding that I can obtain all of this information, where can I obtain baseline values? So, for instance, even if I can determine that my intake manifold pressure is X millibars, what difference does that make if I don't know what the normal spec. tolerances are anyway?
What I am asking is how valuable a tool is this in terms of real world applications for the data obtained?
'95 855 auto (sold)
'95 855 auto (sold)
ezliving4ume
- Year and Model: 850 glt, 1997
I have a s3 android, torque pro is the app and the adapter is a elk327 from new egg. I went with new egg because of the reviews on the adapter. Which were some work and some don't so make sure you can send it back. I didn't have the problem.
I am also struggling with, yes I have the information but what does it mean? It seems that the basic stuff is mia. I can't read engine oil psi or transmission temp.
xtrattitude4u
Fuel trim tells you if your ECU is compensating for a lean or rich condition, very useful for MPG issues.
http://www.obd-codes.com/faq/fuel-trims.php
Viewing your front O2 sensor voltage in real time will tell you if it is lazy or working properly.
http://www.autodiagnosticsandpublishing ... esting.htm
The data you need is out there, just gotta do a little searching.
A failing throttle position sensor can cause many serious drive-ability issues that can be difficult to diagnose.
Viewing the voltage as you sweep through the throttle range will show if it is bad.
(it will jump erratically when you hit a certain point)
This is a test I am going to perform on my fiance's Jeep soon btw.
Comparing data to gauges will show if you have an actual problem, or just a gauge problem.
The ability for you to view any stored trouble codes instantly on your phone and to clear them is worth more than $20 alone, IMHO. You can't really get a scan-tool for that cheap.
I don't have any codes with which to test that, though, and I consider that a good thing.
- osman
- Year and Model: 2002 c70 hardtop
I have a Kiwi by PLX devices ($100) and an ELM327 from Amazon($12) and Torque Pro ($5) on my Motorola Razor Maxx HD running Android Operating System. If you work on your car yourself: THERE IS NO CHEAPER SCANNER (code reader) Than an ELM 327 and Torque Pro ($20) The most valuable tool IMO is that you can read oxygen sensor waveforms in realtime, so instead of throwing money and parts at something like a vacuum leak, or other rich/lean condition that can throw an O2 sensor code, you can see its performance in real time, and 99% of the time ITS NOT the O2 sensor. Just to be able to read codes for $20 is incredible, to be able to read O2 waveforms on a standalone handheld scanner will be $300. Torque can also inform you if your sensors are ready and passing for emissions test for those that have them.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
99 XC70 AWD LPT 115
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
So, any Android device with BT capability should work ok, i.e. doesn't have to be a SmartPhone as such?
I want to buy a Samsung/Acer/Asus android tablet, 10 inch screen and use it for this as well as regular tablet functions. Should work right?
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
PencilShavings
- Year and Model: 1998 Volvo V70
Thats so neat
precopster
- Year and Model: Lots
- Been thanked: 128 times
Any bluetooth capable Android tablet will work. I use Torque Pro and the cheapest ELM327 I could find. I use a Samsung Note 2 smartfone. First connection with my 2000 V70 (Denso) takes afew attempts but after that it's great. I monitor live vacuum/boost, average fuel consumption, present fuel consumption, OBD read speed with correcting factor for oversize tires, engine revs, coolant temp with a pre-set alarm at 108degC (in case of a burst hose)
The only issue is the awkward placement of the OBDII port under the armrest which leaves it in a semi raised position.
You can setup multiple vehicle profiles so you don't have to make adjustments when switching b/w vehicles. Also there's a video plug-in for a couple of bucks to enable video during performance runs, say 0-60mph or 1/4 mile with a whitewashed version of the regular screen
It connects first time every time on my P2 S60 AWD turbo so it must have a more compatible system on the Bosch ECMs.
MrPc
- Year and Model: 850R 1996
I've used the cheap Amazon ELM327 bluetooth adapter and Torque Free with my '96 850R.
I had never had the chance to pull a code with it, because my car never threw any. Nor any stored codes. But the other day while fooling with the upper torque bushing, I accidentally started the car with the accordion pipe disconnected from the maf, throwing a code and illuminating the check engine light.
I was curious to see how my adapter and torque would display the code, so I hooked it up for a look. I was surprised to find no codes indicated at all. I tried a few times with the same result. For kicks, I tried clearing the codes, and the check engine light immediately when out, and has stayed off since.
Has anybody else seen anything like this? Dodgy Elm327 semi-working? Pilot error? Any theories?
Red Red '96 855R, 169k
- 1662 Views
Last post by XC70Rider
- 3709 Views
Last post by ggleavitt
- 2798 Views
Last post by KTTYR
- 2297 Views
Last post by hanacaptain
- 25 Replies
- 7105 Views
Last post by Blacklab467
