I need to replace my pads front and rear? My local stores, Pep Boys, AutoZone, Advance Auto, NAPA only carry a few and only for the front.
Brands = Bendix, Access, Duralast, WearEver and some other no name brand.
Any recomendations? I want low dust and no squeal.
Help, Brake pad recomendations
- Has thanked: 2664 times
- Been thanked: 1256 times
IMHO you can have squeal-less pads (OEM), or dustless pads (aftermarket), but not both.
I put aftermarket pads on my 850 a few years ago, with backing grease, and have had minor squeal since then, only when the pads are cold.
There have been whispers here and there of finding the Happy Medium, but no chorus of agreement. However if anyone reading this has found brake pad nirvana, please speak up on the brand and technique, by all means.
- Tsquared
- Year and Model: 11 C30
- Has thanked: 1 time
I have had good results with the NAPA premium ceramic.
Do a search on ceramic to see past posts.
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
White850Turbo
- Year and Model:
Everyone who has ever run anything but OEM pads on the rear has big problems with squealing. For the fronts, squealing shouldn't be a big issue as long as you use plenty of grease. That being said, the best replacements for the front pads are supposed to be the Mintex C-Tech's; I'll warn you now though that they aren't cheap.
-Sean
1998 S70 T5 (Almost Stock)
Also keep in mind that the harder the barke lining material, the more frequently you will be replacing rotors. These things go through rotors faster then any car I have seen, mostly due to the small pad size and pad materials. I have a set of aftermarket pads in the rear (I don't remember which brand...) and they don't squeal at all. I'll try to find the brand.
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
Guest
I use Genuine Volvo pads along with Brembo rotors on my S70 and 850 and get them from www.fcpgroton.com
30648381 1 Front Pad Set - Volvo $53.00
30648383 1 Rear Pad Set - Volvo $30.00
271788BR 2 Front Brembo Brake Disc $43.00 $86.00
271794BR 2 Brembo Rear Disc $33.50 $67.00
Order Subtotal*: $236.00
- 2916 Views
Last post by styoung94
- 12 Replies
- 2534 Views
Last post by drgswede1978
