Key FOB stopped working
pmcoppola
Year and Model: S70, 2000
Post by pmcoppola »
One of the two remote control key FOBs stopped working all of a sudden with our S70. I checked the battery and it is ok, 3.1v. The other key FOB still works so presumably the controller in the car is ok.
I asked about reprogramming the key FOB in case it lost synchronization with the car but have been told this can only be done at a dealer.
Does anyone have any ideas, short of buying a new key FOB and having it programmed at a dealer?
Has thanked: 1497 times
Been thanked: 3809 times
Swap batteries on FOBs, no-load voltage is mediocre gauge of battery condition.
jreed
Has thanked: 352 times
Been thanked: 192 times
Post by jreed »
I had a similar problem with two key fobs for my '97 855 GLT. Back in September I opened up the unit, cleaned the contacts and added a thin copper strip to the switch mechanism. The fobs have been working fine since then.
You can see my little write up here:
https://www.matthewsvolvosite.com/forums ... 0&p=256777
Good luck! :)
instarx
Year and Model: XC70 T6 2011
Has thanked: 1 time
Post by instarx »
Yep, replace battery and clean the contacts. Use a pencil eraser.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
