98 v70 awd 112k oil leaking problem. Went to a shop for diag
djomlas
Year and Model: 1998 volvo v70
Post by djomlas »
I took the car to firestone since its right down the street and they said oil leak is from the turbo
I looked under w tgem and oil return looks dry and so do the other 2 copper looking lines
I checked if it might be cam leak by distributor but its not coming from there
Regular driving its ok but on full load on highway it leaks pretty bad to the point where whole underside, along with the tailgate and back window is full of oil spray.
Any ideas what to look for or what do do?
Is turbo swap ( from ebay used) a hard thing to do on an awd?
Im looking for pcv kit to be on safe side...
Year and Model: 2004 V70 2.5T
Been thanked: 471 times
Post by cn90 »
Start with 2 items:
1. PCV Overhaul (info in forum)
2. Rear Cam Seals x2 (I use SKF seal, about $7/each; info in forum)
Then clean the engine with some engine degreaser and small amount of water (don't drown the sprak plug areas!).
Then monitor leak, you may have a RMS leak too, which is a pain to fix. But let's hope you don't have a RMS leak.
bskeels
Year and Model: 1997 Volvo 960
Been thanked: 3 times
Post by bskeels »
I just replaced the supply and drain lines on my 98 v70xc's turbo do to a leak, rotted lines. The car only has 143K on it. I found that the supply had a pinhole in it. The drain is a pain to do due to the transfer case. The parts are reasonably priced if you use Volvo country parts.
The Fleet
2012 Ram 2500
97 Volvo 960
98 V70 AWD (208000+)
66 Volvo 122s sedan project
98 Volvo V70 XC (151,000+) parts car
08 Volvo V50 T5
"Human history becomes more and more a race between education and catastrophe" - H. G. Wells
djomlas
Post by djomlas »
I do notice car is way slower, maybe the turbo is really bad
I dont think its rms its pretty dry there
