94' 850 Slightly Rough Idle when cool outside
I've noticed when it's cool outside in the morning, maybe about below 60*F or so, the idle in the car is just a little rough, bouncing around a bit. Doesn't seem to be a big deal, but maybe it's something I can nab early before it's a problem. Anyone had this and figured it out? Thanks again, you guys are awesome!
- Year and Model: Many Volvos
- Been thanked: 75 times
Have you read the codes? If this is a turbo they will all be read in port A-2. On a Non Turbo they can be split up between ports A-2 and A-6.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Temp sensor comes to mind, but start with codes first, if there are any.
If not, test the resistance at the temperature sensor by the thermostat on a cool engine.
* -20C: 16,000 Ohms (16 kOhms)
* 0C: 7,300 Ohms
* 20C: 2,600 Ohms
* 80C: 300 Ohms
* 90C (Operating Temp): 200 Ohms
* 100C: 150 Ohms
* 0C: 7,300 Ohms
* 20C: 2,600 Ohms
* 80C: 300 Ohms
* 100C: 150 Ohms
'98 S70 T5
2016 Chevy Cruze Premier
thanks guys, I'll check those options when I have some time but will be a little busy for the next week. I believe it's had that idle issue since I've had it (about 8 months) and I had checked for codes a couple months ago and didn't have any so might be more likely the temp sensor.
