Hey everyone,
I just purchased a 1994 Volvo 850 Turbo. The person i bought it from said it needs a new PNP switch...I am not sure this is TRUE....when the car turns over and i put it into gear it doesnt do anything...put it in drive and it makes a sound or vibration really quick like it wants to go in drive? Auto transmission too
so it just doesnt go into gear.......
94 850 turbo No engagement of auto transmission
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Reverse lights come on when the car is put into reverse? If so, and it's not very touchy about where the lights come on, the PNP switch is probably aligned and working just fine.
+1, check the fluid.
'98 S70 T5
2016 Chevy Cruze Premier
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Sorry but it's not possible to check fluid level if you can't drive the car. What I would do is pull the drain plug and inspect the fluid, then add back 3-3/4 quarts.
Also, does the reverse lights come on when placed in reverse?
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
Even though the car won't move, you can start it, try shifting through the gears, let it idle, oh maybe 10~15 mins or so and check the fluid. If you see none, maybe that's it or if it is really nasty try changing it. I MIGHT BE WRONG, but I think letting it idle for a while should warm up the fluid enough to see it on the dipstick. Any chance the radiator broke and let water leak into the tranny?
PS, this isn't an accurate way to measure fluid level, just possibly a way to see if there's any in there. You must drive the car to read accurate levels.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
rmmagow
Check your drive shafts, make sure they didn't pop out from the tranny.
- 21 Replies
- 4171 Views
Last post by zupta82
- 2201 Views
Last post by koolhandluke
- 596 Views
- 1784 Views
Last post by mf70
- 884 Views
Last post by robin_740
