Cheap HF scanner with amazing potential.
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
Harbor freight has this scanner for $99 right now. You can also throw one of their 20% off coupons at it. http://www.harborfreight.com/can-obd-ii ... 60794.html
Now....HF's scanners are rebadged Autel's, more than likely this is just an updated clone of the US703. The US703 and the EU702 do ABS, Trans and SRS, the only difference between the two is the files loaded into it. Amazon usually has them for $150+ and they're worth every cent of that. Let's say you buy a US703 that only does domestic cars. You CAN add any of the Euro or Japanese files to it and basically have a scanner that will read about anything.
I'm going to go buy one of these tomorrow at lunch and see if I can add the some files to it. You can't beat having a scanner that will do all of that for under $100.
Autel's aren't bad. They are quirky and you have to figure out how to get around some of those quirks, but they're incredibly durable. I've done at least 1000 scans with mine.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Matty Moo
Has thanked: 1 time
Post by Matty Moo »
After looking into it more, it's a rebadged Autel MS609, which supposedly does ABS and SRS on everything and it's also around $80.
I'm going to get one or the other and see how it works and what I can do to change it up.
2000 s70 GLT
2014 Ram
