can't get me brake caliper to compress
joebone
I can't seem to get my brake caliper pistons to compress so I can't change my pads! Anyone have any ideas how to fix this? I tried a pry bar, and a wrench-no luck.
- Tsquared
- Year and Model: 11 C30
- Has thanked: 1 time
Use a C clamp. Leave the old pad in the caliper and compress the piston with the C clamp. Use a liberal amount of cleaner to brake away any crud or corrosion.
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
volvito
did you open the fluid tank and removed some fluid before pushing the caliper ?joebone wrote:I just needed a bigger pry bar...thanks for the advice!
