1999 S/V70 Repair Database MAP IAT for ETB
Has thanked: 1505 times
Been thanked: 3817 times
Thread to document location and removal of the Intake Air Temperature (IAT) and Manifold Air Pressure (MAP) sensor on Electronic Throttle Body Volvos
Part number for IAT is
Test data
Temp C Resistance in Ohms
0 16kOhm
10 9.6 kOhm
20 6.0 kOhm
30 3.9 kOhm
40 2.6 kOhm
part number for MAP is: 915870
Pressure KPa Measured Voltage
90 1.70
100 1.90
150 2,8
200 3.7
Pictures with captions on these two sensors
View of the MAP sensor removed
You have to open the ears slightly with a screwdriver and then wiggle the MAP sensor out - mine was quite tight
With the intake air hose removed, you can slip a small screwdriver in to release the MAP ears
Closeup of the IAT - be careful handling this one
Once the IAT electrical plug is removed, squeeze the ears and lift it straight up out of the ETB manifold
Squeeze here, and pull connector of IAT
Here are the two sensors on the ETB - one for temp, one for pressure
Here is where we will be working today. Get the air cleaner hose out of the way for space - it just slips on both ends (red oval)
