Check engine light reset Topic is solved
guest
Can it just be reset by unplugging the battery? or do you definately need a reset tool? Thanks
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 2 times
Depends on the year. '96-'99 have to have a code reader to reset them.
robert213
- Year and Model:
The service light cannot be turned off by disconnecting the negative terminal of the battery. For 1993-95 model years, there is a procedure of using a jumper pin and pressing a button in a specific coded sequence.
- 887 Views
Last post by martin9586
- 1806 Views
Last post by durk80
