2003 S80 T6 auxiliary fan won't shut off
I had to disconnect the battery cable for a repair now the auxiliary fan continues to run.
rerobin66
- Year and Model: 2000 S80 T6
- Been thanked: 2 times
lol....these S80 are so alike. All summer we have had this with my 2000. We just made sure the ac and/or heater was not on when we shut the engine off and it was only temporary that it ran. Check forum topics that have this issue for info. Sorry I am not more help.
1999 GMC Sierra
1964.5 Ford Mustang
2000 S80 T6
1964.5 Ford Mustang
2000 S80 T6
jimmy57
- Been thanked: 320 times
If the battery is disconnected within 5 minutes of ignition being switched to off position you can have an issue with network error codes and some error handling effects will occur like the fan running.
Disconnect the battery and then hold the removed the ground lead to the positive cable post to assure the capacitors are discharged in all modules. This will allow a full reset to occur.
