I have had the Brake Control Module (BCM) rebuilt and replaced after an intermittent... then, eventually solid "Brake Failure" warning light. Odometer and cruise control stopped working as well. Same condition after the BCM was replaced. It seems that the front driver side wheel spins out very easily on gravel. Is it possible that the wheel speed sensor is malfunctioning on the front driver side wheel?
Where can I access the plugin point for the individual wheel speed sensors?
Is there a location other than at the main plug on the BCM?
If not, does anyone have the 'pin out' sequence for each wheel speed sensor? (photos would be nice!)
Any other related input is encouraged!!!
04 XC90-T6 Loc Front Wheel Spd Sensor Plug In
