CBV Compressor Bypass Valve Operation
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
boosted5cyl
Year and Model: '98 V70 T5, '99 S80
Post by boosted5cyl »
So the tube from my CBV to the inlet pipe busted, time for a new one of those. However I noticed there is quite a bit of air flowing out from the CVB, back towards the inlet pipe at idle, I assume that means it's leaking?
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
boosted5cyl
Having read this it seems that the valve is meant to be slightly open under vacuum. Seemed a little odd to me but there you go. I guess I'll whip it off when I get the pipe and pressurize it to see if it holds pressure. I do get weird "ghost" like noise when cruising so might be time for a replacement anyway.
Part number for the hose is 1270319, which is imaginatively called "hose" in VADIS.
