hi there s80 awd v8 has hard change between 1st and 2nd gears only there is no fault code stored on the gearbox or the engine and when stopping in traffic high idling is being experienced please advise possible causes and repaired needed thanks
barno
2007 s80 awd v8 irratic gear change 1st and 2nd
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
Possibly a mas airflow sensor going south or a vacuum leak. You can have either of these bad enough to cause weird running, but not throw a code.
Try driving with the MAF disconnected for a short period of time and see if the symptoms change.
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
