I can't remember....Is there a small light that comes the lights are turned on located in the ashtray? I seem to think there was a light greenish glow at some point during the night.
I have a 850GLT
Is there a light in the ashtray?
White850Turbo
- Year and Model:
There is a green light that lights up in a ring around the cigarette lighter.
-Sean
1998 S70 T5 (Almost Stock)
viper69
- Year and Model: 850GLT 1995
- Has thanked: 77 times
- Been thanked: 2 times
hmm could have sworn there was in inside the ashtry..above it...weird..thanks
Volvo 850 GLT 1995
5 Speed Manual transmission
122,500 miles and barely broken in
'82 Volvo DL Wagon, 4 speed manual
'77 Saab 99 EMS, 4 speed manual
White850Turbo
- Year and Model:
Darn, and I thought I had just finished replacing all of my stupid interior bulbs. ALL of mine were burnt out.kelvin6 wrote:Front or rear? They both have one. The one in the rear is shared with the light inside the center console box. Dealer charges $6 for that stupid bulb.
If it's the wedge type of bulb, I believe Sylvania makes a replacement that you can get at an autoparts store. The part number is 2721.
Oh, and if you want to replace all the super tiny bulbs in the switches (headlight switch, fog light switch, etc.), look for a 3mm LED w/ about a 20 mA draw. You can also get a 2 pack of light bulbs from radio shack for $1.49 (part # 272-1092). Either way, you'll need to solder them in, which is very easy to do. Well worth the money saved.
-Sean
- Has thanked: 312 times
- Been thanked: 818 times
No soldering at all on the switch bulbs, just pop them in and wrap the wire contacts. Part numbers including for radio bulbs, links and an example of how to replace the switch bulbs: viewtopic.php?t=67244
Mouser (see above) is a better source for incandescent switch bulbs.
You can use the switch bulbs for the ashtray and shifter etc as well, no need to shell out $6 for a little light. So buy a few extras and be set for years.
- raivis_rsn
- Year and Model: V70 1999 TDI
- Been thanked: 7 times
20mA could be pretty dim. I measured original bulbs and they are about 80mA. It's really hard to find so powerful bulbs but 60mA are available widely.White850Turbo wrote: 25 Dec 2005, 00:41 Oh, and if you want to replace all the super tiny bulbs in the switches (headlight switch, fog light switch, etc.), look for a 3mm LED w/ about a 20 mA draw.
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
If you're changing to LEDs, you should definitely not look for something in the same range as the originals. White850Turbo is right - I changed my switch bulbs to those LEDs, and that's about the same amount of light as the old ones put out. A little "clearer" even, I'd say.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- misha
- Has thanked: 155 times
- Been thanked: 432 times
No...it's separate light with it's own socket.kelvin6 wrote: 24 Dec 2005, 19:05 Front or rear? They both have one. The one in the rear is shared with the light inside the center console box. Dealer charges $6 for that stupid bulb.
@ Viper69...you need to remove front ashtray mechanism in order to replace the bulb.
It's held with 2 torx bolts on each side visible when you open the ashtray.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 2356 Views
Last post by Jeney
- 2414 Views
- 903 Views
Last post by kaneelschep
- 968 Views
Last post by JRL
- 1782 Views
Last post by 90 Beater
