1997 V40 new CV Joint doesn't fit hub
1996 - 2004 S40
1996 - 2004 V40
V40D
Year and Model: 1997 v40
Post by V40D »
Hello
I've purchased an after market new CV Joint drive shaft with both inner and outer cv's. The inner fits ok into the transmission, but I cannot seem to be able to fit the outer spline on the outer cv joint into and through the hub. It seems that the spline is 1 mm bigger in diameter.
Is it possible that my car is an early 1997 model and there was a change to the splined shaft size?
shanegtr
Year and Model: 1999 V40 2.0T
Post by shanegtr »
I know that there is a difference between the turbo and non turbo's. Turbo hubs have a 21 spline hub vs. non turbo 20 spline
Give it some Jandal!
