My 93 850 has been having problems with the idle for a month now. I've recently replaced it with an after market fuel injectors, Volvo IAC valve and Volvo TPS.
When the car's RPM drops below 800, I can hear a beeping sound (like a pager) near the fuel injector 1. Dont' know exactly where but it's close. Can it be the thermostat?
Also when the engine warms up, my idle goes crazy up and down from 1500-2000 rpm. Hence the replacement of the IAC and TPS.
Any suggestions from any one?
93 850 Beeping Sound
White850Turbo
- Year and Model:
Any more codes? It sounds like it could be a faulty engine coolant temperature sensor.
-Sean
1998 S70 T5 (Almost Stock)
White850Turbo
- Year and Model:
http://www.volvospeed.com/CheckEngine.php <-- You don't need a reader to check codes on that car.
-Sean
White850Turbo
- Year and Model:
For the ECU on your model year car, 2-1-4 is listed as "RPM Sensor signal sporadic". Okey, so the first step would be to inspect all of the wiring to and from the sensor to make sure there are no loose connections/shorts. If none are present, you'll need to replace the sensor. It is located on the rear of the transmission housing. It isn't a terribly uncommon problem on these cars.
-Sean
- 626 Views
Last post by Cees Klumper
- 1058 Views
