1999 volvo s80 battery dead, cant unlock trunk,no master ke
btdelooney
- Year and Model: 1999 s80
Please help - the battery is dead/needs replacment. mechanic cant unlock trunk (i am at work) and we lost the master key (only have the valet I guess). Is there anything that can be done? Thanks in advance
JDS60R
- Been thanked: 3 times
Of course. ( but the valet key should have at least opened the doors so he could add power to the cig lighter etc enough to allow the remote to open the trunk)
Slide under the car ( jack up safely if needed) and run jumper wires to the positive on the starter and a ground to the body. Then use your remote.
Retired
btdelooney
Thank you, the car was jumped. the cigarette light hasnt worked in years and of course we cant locate the remote. Is there a latch/chord that is accessible from inside the trunk. my mechanic said there is on newer models but couldnt find it when he put the center console down and looked with a flashlight. thanks again.
btdelooney
yes but that wasnt working as of 90 minutes ago anyway when I last spoke to mechanic. unless there that latch inside trunk i will have to scour my house for master key. appreciate the help
jimmy57
- Been thanked: 320 times
Raise hood and put battery charger (+) on the jump terminal and ground on engine somewhere.
Then use remote or button door after charger has been on for a few.
Oly_850
- Year and Model: 2000 S80 T6
Ditto. Open the hood, jump to positive wire cluster near LH strut tower, ground to engine block or what have you. Charge. Use lock button to unlock all doors. Try trunk.
'12 Ford Focus SE - Black Pearl
Owned:
'00 Volvo S80 T6 - Maroon
'98 Volvo V70 - Red
'90 Volvo 740 GLE - (sold, too far gone)
'96 Volvo 850 GLT - (totaled) :\
Want - A6 Quattro, XC90, C303
Owned:
'98 Volvo V70 - Red
precopster
- Year and Model: Lots
- Been thanked: 128 times
Another way is if you connect to Vida/Dice while adding another battery up front at the jump point you can activate the boot release through Activations.
- 767 Views
Last post by DavidE7
- 4996 Views
Last post by quietcoolone
