This is FCP. How are we doing?
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
Hey Everyone,
This is Ed Santandrea from FCP and I am the customer loyalty manager, basically working on ways we can make the FCP experience the best possible for both new and returning customers.
We just completed our annual survey, so some of you may have already provided feedback there, so thank you. I did however want to introduce myself here since many of you have had a lot of experience with FCP over the years (both good and bad) so I thought it would make sense to reach out to you all a little bit more personally than a survey and ask again -
“How are we doing?”
-Ed
kcodyjr
Year and Model: 2006 S60 2.5T AWD
Has thanked: 17 times
Been thanked: 23 times
Post by kcodyjr »
Generally very well, Ed. As parts companies go, you're unusually friendly to the whims and screwups of do-it-yourselfers. I've never had trouble with odd requests from your customer service staff. I often recommend you to other shade tree mechanics, and I always make sure pros have heard of you.
Also, I'm lucky enough to be near the same regional UPS hub as you. The brown truck takes it straight from your loading dock to my town and I get it the next day, even if it's just ground service.
If you're looking for problems needing solving, you'll have to wait for the next guy. The closest I could come is parts comprehensiveness; I have to call you on the phone, which I'll be doing shortly, if I want the coated version of Zimmerman's cross drilled rotor.
If you're looking for somewhere you could grow, I'd suggest kits. You've got some, but only for the obvious.
Specifically, there are write-ups all over this site, for anything from a PCV job to e-brake cable replacement to interior mods. I'd suggest you assign someone to pick through the repair database and look for anything that needs a collection of particular parts, then put together single-click kits. You could even generate some cross-advertising by putting them in a new section, "MVS Repair Kits," with links to the ever-evolving instructions to accompany those kits, and I'm sure Matthew would be glad to reciprocate.
Just a thought. Other than that, keep up the good work.
5 others that came and went
FCPEURO
Post by FCPEURO »
kcodyjr – Thank you for your feedback. Many of our customers work on their own cars, so it makes sense to have people here to answer their questions because we think that is part of good service. Thank you for the suggestion on the kit, great idea. Much appreciated - Ed
McBEAST
Year and Model: 1997 850
Post by McBEAST »
I've used FCP a few times before because of the good reputation and screwup-free help I can get. However, I was looking at wheel bearings on your website and you seem to want $140 each where I can get it at local shops for $20. That really deterred me using your website because when I was looking at products, I just kept noticing you have higher prices than any other retailer. Is it just because you're a small company? Is it because you have such good customer care?
Has thanked: 1613 times
Been thanked: 4078 times
Are you looking at same part and mfg? There are lots of cheap junk parts out there and wheel bearings are a prime example. FAG or Timken will cost more and last for the rest of car life.
Sagan
Year and Model: S60 2008
Post by Sagan »
My one experience with a PCV kit was spot on. Friendly staff when I called about delivery and all parts included in kit. Saved about 50.00 off retail. No complaints here.
syrotchen
Year and Model: 2002 S80
Post by syrotchen »
Ed,
I recently had to RMA an aftermarket CAT when it kept tripping an efficiency code. I actually took it to a shop and had them verifty I had a bad CAT and not another issue, as I was expecting problems when I went to return it. Instead what I got was an outstanding customer support. Your specialist was knowledgeable and worked with me to keep me on the Road. I paid for a new cat and you shipped it out so I could swap the Cats and then be refunded the purchase amount. The process was flawless, despite the fact that it took me a month to get the bad one back to you. The one area I have had problems with in the past was getting the correct part. I've never had a problem returning the incorrect part, but as I stated in my survey, getting it right the first time is important. My recent purchases have been spot on, but I've had only a couple of orders so its hard to say if you made improvements in accuracy. Thanks for the great customer service.
