Looking for a Fuel sending unit for an AWD 98 V70
I need a fuel sending unit for an AWD 98 V70. I broke mine doing an install!
Bluevanacd2005
- Year and Model: 1983 760
I have a complete unit still in the tank of a 2000 V70R... Not sure if they are the same though.
I like curves on my women, not my cars
Bluevanacd2005
Give me about a day and a half to pull it from the car and take some pictures. I can't do it today because I have school right after work.
-Spenser
-Spenser
Bluevanacd2005
I got some extra time to pull the round metal plate held on by 5 10mm nuts on the rear floor of the car. For some reason I was under the impression (purely an inaccurate assumption) the sending unit and pump were directly beneath it. Removing it proved otherwise. The car is outside on blocks, and its been pretty cold out (10F), so it may be a bit before I can get the tractor out to lift the car and drop the tank. I don't have a problem doing this, but if you are waiting on a sending unit to put your car back together, it may be quicker to source it elsewhere.
Sorry,
-Spenser
Sorry,
-Spenser
b2fkb0
- Year and Model: V70r,855r,s70t5m,xc
- Has thanked: 5 times
- Been thanked: 4 times
Spenser, you can cut the floor right over the pump and take it out. I did this to my daughters r and then took the cut piece and welded tabs for remounting. Since yours is a parts caR, a little grinding and she'll be out. Probably take less time to cut the hole. Call me and I can explain.
Dan
Dan
Bluevanacd2005
Is it near the access cover?
