240 wagon won't start
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Carmen
Post by Carmen »
1993 4-cly 240 wagon
engine will not start- battery is good, light, horn work
engine will start if I attach jumper cables from running car as soon as I disconnect cables engine dies
Any idea where the problem is?
Thanks,
Carmen
Guest
Post by Guest »
clean and tighten your battery terminals. with headlights on measure voltage drop from positive post to positive connection on starter you should have very low reading (.02v) do the same on the negative side you should have the same result if you get a higher reading you have a poor connection or a bad cable. are you sure your battery is good? headlignts and horn can work and battery still not have enough life to start the car.
