98 S90 250,000 Miles
lindy8_man
Year and Model: 1998 S90
Post by lindy8_man »
YEA!!!!
Just rolled over my Odometer to $250,000. We bought the car in 2005 with 137K. Only real problem between there was the Vacuum motors under the dash, A new transmission (A sensor degraded and was eaten up by the transmission), and the Radiator had to be replaced. Not too shabby in 9 years! The car is easy to work on! I'll keep this car as long as I can.
Beer and DIY Volvo Repairs are proof that God loves us and wants us to be happy.
voodoorobaz
Year and Model: 1982 Volvo 245 DL
Post by voodoorobaz »
Awesome!!!
1998 Volvo S70-Gone
2002 Volvo S60 T5-Gone
2000 Volvo V70 XC AWD-Gone
1983 Volvo 245 Dl-Gone
1982 Volvo 245 DL
2013 GMC Terrain with 3.6l
2006 Cannondale Bad Boy Use for Commuting to work
danr960
Year and Model: 964 1994
Post by danr960 »
Congrats, if they are maintained, most will perform as yours. Good job.
How is your oil usage? I ask because, I bought my '94 in '95 and from that day on it hovered around 1300 miles per quart. It gradually worsened until I swapped the engine out at 234,000 miles, by then it was a quart every tank fill. I guess, I got a bad engine, I think it was the wrong size pistons for the bores in the end, it was doomed from the beginning.
Good job.
DanR '94 964 388,000 miles (154,000 on the new engine)
98S90
Year and Model: 1989 S90
Post by 98S90 »
lindy8_man wrote:YEA!!!!
...A new transmission (A sensor degraded and was eaten up by the transmission), ...
Great! I just bought a98 S90 with 174K. Any tell tales on the sensor going out?
lindy8_man
danr960 - Well, I use about a quart per 3K. I have to be sure and change the oil on time, or at least put in a quart... My understanding is that the valve seals get hard and leak oil over time. I was told to only have the head rebuilt when I feel it is time. New engine not necessary.
98S90 - Sorry no luck there. I was pulling the cuyamaca mtns. with a full load out of Yuma to SD in the summer. I could tell it was working hard. I think the sensor failed going over. the following weekend I was screwed. The ECU put me into limp mode and there was nothing else to do. I do believe these transmissions run hot. I had to replace the radiator, and I put in a metal one to keep from the plastic breakage that left me stranded. I don't think the metal one had the cooling capacity the OEM had for the transmission. After I made the switch, I had funny shifing issues, where it seemed like the shift would bounce between gears, and shift down too soon. I put in an auxillary transmission oil cooler and the problem went away.
