91 740 Horn doesn't work
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
neworleans
Year and Model: 2007 S60R
Post by neworleans »
Hello mates,
I need to fix my horn to pass the inspection but I don't know what to check or where to start to check.
Any help would be appreciated it....
voodoorobaz
Year and Model: 1982 Volvo 245 DL
Post by voodoorobaz »
I would make sure the fuse is good 1st thing. Then you could check to see if your getting power to the horn and that the horn ground is good. If no power to horn itself, the problem will be in the wiring from steering wheel contact for the horn or a broken power wire itself. To get thru inspection you could always install a secondary button for it just to get it to pass unless your inspection requires it to work from factory installed button.
1998 Volvo S70-Gone
2002 Volvo S60 T5-Gone
2000 Volvo V70 XC AWD-Gone
1983 Volvo 245 Dl-Gone
1982 Volvo 245 DL
2013 GMC Terrain with 3.6l
2006 Cannondale Bad Boy Use for Commuting to work
