1994 850 Turbo Shift Cable
thejasper82
Year and Model: 850 Turbo 1994
Post by thejasper82 »
Hello every one,
Earlier I tried get at gear position sensor/PNP/Neutral Safety Switch on transmission, I took shift cable off from arm but afterward of trying to get gear position sensor, I gave up and put back everything. When shifting gear into any position it doesnt stick in place and also when I pull and push the arm at gear position sensor the shift cable does not stay in place, it pulls when I pull the arm so it must be loose. How do I adjust the shift cable, tightening on where and looking from whatever view, tight to clock-wise or counter clock-wise? Pics would be real helpful.
Thanks!
Jesse
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Hot off the press:
