98 V70R Compared To A 98 V70 AWD
rmmagow
Year and Model: V70 1998
Been thanked: 2 times
Post by rmmagow »
A friend has asked me to help with his V70R. I have a V70 AWD. Both are 98's. Is the vac plumbing, electrical, most mechanical pretty much the same? I'm going to look at how my TCV is connected and compare to his as well as SAS related components and the EVAP system. At first glance, they pretty much look the same. My car works fine, his not so much.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
osman
Year and Model: 2002 c70 hardtop
Post by osman »
Yes, the only difference is the AWD. Obviously the AWD is an LPT and the R's ECU/suspension is different, everything else is the same.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
osman wrote:Yes, the only difference is the AWD. Obviously the AWD is an LPT and the R's ECU/suspension is different, everything else is the same.
shouldn't the R be AWD as well ?
rmmagow
Post by rmmagow »
Yeah, it is. Mostly I'm just helping with the standard busted vac line codes and some ignition problems. More or less a stage 0 and teaching lesson. I'm no master mechanic but in the kingdom of the blind....
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Just about EVERYTHING is the same except the engine
jimmy57
Been thanked: 320 times
Post by jimmy57 »
The things you asked about are the same. The engine is a different displacement but the service things are the same. Same plumbing for crankcase vent system, turbo control valve, and fuel lines.
When you are done do not expect to run like yours. Your LPT will outrun it initially. The R engine only shines at higher revs when its turbo is in its sweet spot and the torque limiting program for R's of that year is no longer hindering the engine.
osman
Post by osman »
I believe the years of R's that arent AWD is 96, 97. I wasnt sure about the 98's.
Brick Life
99 XC70 AWD LPT 115
rmmagow
Post by rmmagow »
They would have been 850's right (US)?
osman
Post by osman »
Correct.
Brick Life
99 XC70 AWD LPT 115
rmmagow
Post by rmmagow »
So, V70 T5, 850R's are FWD w/HPT? Sounds like fun. My very first Volvo was a 98 V70R but repair forums were pretty much limited to rec.autos.tech BBS system. The car just plain spooked me and I dumped it as soon as I fixed the big stuff. Had I known about MVS (if it existed then) I'd still be driving it. HPT is a blast to drive, but the LPT is a better commuter and stuck-in-traffic car.
