1999 S70/V70 Seat Swap?
larrico
- Year and Model: 1991 940SE, 1999 S70
Have a 99 S70 GLT with a manual passenger seat and a V70 with a power passenger seat, would these two seats be interchangeable? If they are it's essentially 4 bolts and the pigtail?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
If they are both '99 models. You need to check to see if they both have the same seat air bag system. I have seen a '99 car with manual air bag.
Also, there is a chance that the manual car is NOT wired for a powered seat. Check that before you swap it if it matters.
Disconnect the battery so you don't trigger the SRS code.
- osman
- Year and Model: 2002 c70 hardtop
Easiest way to do this is look for a thick orange wire that is the SRS cable. Make sure if yours has one that the replacement does too or else you will set off the SRS light.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
99 XC70 AWD LPT 115
mikealder
- Year and Model: V70 2000
- Been thanked: 13 times
Check the plugs under the seat, you should have the following:
two pin green and purple connector which is for electrically fired SIPS bags.
two pin grey connector which is for the seat belt fastened signal.
six (or possibly five) pin plug which is seat heaters
four pin plug which is for powered seat motors
- Mike
- Mike
