1994 Volvo 850 Blower Motor
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
For the last month I have only been able to use my fan on high because the resistor went out. I have just not been in the mood to fix it since here in Chicago we have had a brutal winter and I don't have heat in my garage. As you know, without the resistor working properly the fan only works on the highest setting. Yesterday, the fan went out completely. I checked the fuse box and it wasn't blown. Is there another resistor for the high setting? I don't think it's the motor, I've had blowers go out on me before and typically it makes some noise before it conks out. Any suggestions would be greatly appreciate.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
No other resistor.
It's like a 15 minute job that can be done with the car warmed up and you can stay in the car. LOL
shaker_chi
rspi, Why doesn't it work on the highest setting? Is there a breaker or is the fan bad?
Shaker
Shaker
- Has thanked: 292 times
- Been thanked: 765 times
It's probably the fan. A sticking fan (or clogged cabin filter) is what usually kills the resistor in the first place.
Is your car MCC or ECC?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Tons of posts about this if you want to do some searching, here is a good example:
https://www.matthewsvolvosite.com/forums ... =1&t=23749
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
shaker_chi
Thanks ErikV. I have a MCC system.
- 1614 Views
Last post by Ozark Lee
- 2598 Views
Last post by NYVolvo1994
